May 27, 2012, 10:25:50 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Feature Requests
| | |-+  Rotational offset on Z plane
Pages: « 1 2 3   Go Down
Print
Author Topic: Rotational offset on Z plane  (Read 1338 times)
rrc1962
Active Member
Offline Offline
View Profile
« Reply #20 on: December 07, 2010, 10:45:19 PM »
Hmmm...If I rotate the part with X0Y0 it works fine.  If I rotate using a X or Y value to keep the origin at the lower left of the part, I get errors.
If I rotate 90 degrees around X0Y0 the part origin shifts to the lower right.  Is there another offset command I could use after the G58 to correct that?
BR549
Active Member
Online Online
View Profile
« Reply #21 on: December 08, 2010, 12:37:41 AM »
Have you tried rotating the prgram from the MDI page LH side coord rotation box to see if there is any difference in the error ?
When you rotate the part the 0,0  goes with the rotation so it will rotate the angle as the rotation angle
Just a thought, (;-) TP
« Last Edit: December 08, 2010, 12:40:30 AM by BR549 » Logged
BR549
Active Member
Online Online
View Profile
« Reply #22 on: December 08, 2010, 01:05:55 AM »
OK I rotated serveal other test files and finally got one to error on an arc when rotated with a G68 call with an OFF 0,0 rotation point.
SO there IS a problem here with arcs and G68 call .  Not all arcs fail and never from a 0,0 rotation point. The arc that failed was a G3.It also never failed from teh Rotation window on the MDI screen.
THanks for the extra testing, (;-) TP
« Last Edit: December 08, 2010, 01:13:10 AM by BR549 » Logged
Pages: « 1 2 3   Go Up
Print
Jump to:
