May 27, 2012, 10:23:38 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  macropump does not work
Pages: 1   Go Down
Print
Author Topic: macropump does not work  (Read 290 times)
duritskiy
Holding
Offline Offline
View Profile
« on: November 30, 2010, 03:54:03 PM »
macropump does not work in new versions MACH3.
why?
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: November 30, 2010, 05:04:20 PM »
It does for me, check you have it enabled and have it in the correct macro folder.
rrc1962
Active Member
Offline Offline
View Profile
« Reply #2 on: December 01, 2010, 09:59:42 AM »
I've found that I have to enable the macro pump twice to get it to stick.  First time I enable it, exit Mach then restart, I find that the macro pump in general config is still disabled.  If I enable it again, exit and restart, it stays enabled and the macro pump works.
Pages: 1   Go Up
Print
Jump to:
