Hello Guest it is June 10, 2026, 08:23:30 AM
Author Topic: Jog slows down  (Read 20928 times)
Re: Jog slows down
« Reply #10 on: November 28, 2010, 07:20:25 AM »
Can you attach your xml please and I will see if I can replicate here.
Re: Jog slows down
« Reply #11 on: November 28, 2010, 10:04:03 AM »
Sorry new to this what is XML? and I will send it.
Re: Jog slows down
« Reply #12 on: November 28, 2010, 12:36:04 PM »
The xml is the file that holds your config settings, you will find it in the main Mach3 folder. It will be called by the name of the profile you use so if you start Mach have a look down at the bottom right of the main screen and you will see the profile name. Look for the xml with that name, copy it to your desktop and rename to tonymelia.xml then use the additional options button on the reply page to attach.
Re: Jog slows down
« Reply #13 on: November 28, 2010, 02:45:57 PM »
I think this is the one
Re: Jog slows down
« Reply #14 on: November 28, 2010, 05:03:06 PM »
Not seeing that problem here so far when using your xml. I am poresuming it is the DROs in Mach and the tool display as well as your motors that are slowing down?
What is the frequency showing on Diagnostics page and also what is Time in Int, also check CPU usage and see if its loading up, especially when things slow down.
Re: Jog slows down
« Reply #15 on: November 29, 2010, 08:13:02 AM »
CPU is ok but the pulse frequency when running OK is 25,387 but slows to 100 when everything slows. Yes it is the DRO's and the tool display as well as the motors.
Thanks for your help Hood.
Re: Jog slows down
« Reply #16 on: November 29, 2010, 08:33:39 AM »
Definitely a problem with the computer then, not sure what to suggest apart from maybe try to optimise things, there is a text file on the downloads page detailing some steps you can try.
