Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 10:10:28 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Please help - no tool path generation and trouble with X0Y0
Pages:
1
2
Go Down
« previous
next »
Author
Topic: Please help - no tool path generation and trouble with X0Y0 (Read 705 times)
Active Member
Offline
Carnoustie, Scotland
Re: Please help - no tool path generation and trouble with X0Y0
Reply #10 on:
November 28, 2010, 06:27:55 PM »
You have Inputs 1 and 2 set to the same Port and Pin numbers as OEM Triggers 1 and 2, could that be your issue?
LC
Active Member
Offline
Reply #11 on:
November 29, 2010, 12:31:12 AM »
Thanks for replying Hood, but sorry, to me that sounds like you are speaking Swahili.
All I know is the machine has worked flawlessly for 12 months before this happened. So I'm guessing the hardware set-up is correct and I have a software problem.
Unless... while the machine was running I used the drill press. Would starting that have caused a voltage fluctuation that may have corrupted a file?
I really don't know what I'm talking about so I'll accept any advice I can get.
Regards, LC
Active Member
Offline
Reply #12 on:
November 29, 2010, 02:15:32 AM »
What I was meaning is if you go to Config menu then Ports and Pins then finally Inputs and scroll down you will see you have Input1 and 2 set for Port 1 and Pins 11 and 12 respectively. If you scroll down a bit further you will see OEM Trigger 1 and 2 are set up to the same port and pins. This shouldnt in itself cause problems but you may be getting some interference between them.
I am not seeing any problems here with the xml myself but you may have Brains or Plugins operating that I dont have.
LC
Active Member
Offline
Reply #13 on:
November 29, 2010, 03:53:54 AM »
I think I have a lot to learn.
I need to run a test but the solution may have been found. In the error message there is an email address. I contacted Greg at warp9td.com and he sent me an updated plugin for smoothstepper. I installed that, restarted and again had the same error message and problem. Then, after resetting a couple of times things seemed to go back to normal - Yeehaa. I'll run a test tomorrow.
So it may have been a smoothstepper problem, not a Mach3 problem.
Thanks again for your help. I'll let you know the outcome.
LC
Active Member
Offline
Reply #14 on:
December 01, 2010, 01:45:02 AM »
Problem is solved. Just ran the machine and it appeared to work fine.
Thanks, LC
Last Edit: December 01, 2010, 01:54:46 AM by LC
Active Member
Offline
Reply #15 on:
December 01, 2010, 02:53:28 AM »
Good to hear you are running.
Pages:
1
2
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
