Hello Guest it is June 12, 2026, 11:19:28 PM
Author Topic: Please help - no tool path generation and trouble with X0Y0  (Read 19168 times)
Re: Please help - no tool path generation and trouble with X0Y0
« Reply #10 on: November 28, 2010, 05:27:55 PM »
You have Inputs 1 and 2 set to the same Port and Pin numbers as OEM Triggers 1 and 2, could that be your issue?
Offline LC
  •  8 8
« Reply #11 on: November 28, 2010, 11:31:12 PM »
Thanks for replying Hood, but sorry, to me that sounds like you are speaking Swahili.
All I know is the machine has worked flawlessly for 12 months before this happened. So I'm guessing the hardware set-up is correct and I have a software problem.
Unless... while the machine was running I used the drill press. Would starting that have caused a voltage fluctuation that may have corrupted a file?
I really don't know what I'm talking about so I'll accept any advice I can get.
Regards, LC
« Reply #12 on: November 29, 2010, 01:15:32 AM »
What I was meaning is if you go to Config menu then Ports and Pins then finally Inputs and scroll down you will see you have Input1 and 2 set for Port 1 and Pins 11 and 12 respectively. If you scroll down a bit further you will see OEM Trigger 1 and 2 are set up to the same port and pins. This shouldnt in  itself cause problems but you may be getting some interference between them.
I am not seeing any problems here with the xml myself but you may have Brains or Plugins operating that I dont have.
Offline LC
  •  8 8
« Reply #13 on: November 29, 2010, 02:53:54 AM »
I think I have a lot to learn.
I need to run a test but the solution may have been found. In the error message there is an email address. I contacted Greg at warp9td.com and he sent me an updated plugin for smoothstepper. I installed that, restarted and again had the same error message and problem. Then, after resetting a couple of times things seemed to go back to normal - Yeehaa. I'll run a test tomorrow.
So it may have been a smoothstepper problem, not a Mach3 problem.
Thanks again for your help. I'll let you know the outcome.
Offline LC
  •  8 8
« Reply #14 on: December 01, 2010, 12:45:02 AM »
Problem is solved. Just ran the machine and it appeared to work fine.
Thanks, LC
« Last Edit: December 01, 2010, 12:54:46 AM by LC »
« Reply #15 on: December 01, 2010, 01:53:28 AM »
Good to hear you are running.
