May 27, 2012, 10:04:48 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Brains Development
| | |-+  Stuck on brain
Pages: « 1 2 3   Go Down
Print
Author Topic: Stuck on brain  (Read 1550 times)
rrc1962
Active Member
Offline Offline
View Profile
« Reply #20 on: November 27, 2010, 10:44:22 PM »
Is the non-plugin interface is just a serial connection from the PLC to the PC?  Is there a screen in Mach where you set up the PLC inputs and outputs?  Something like the ports and pins inputs and outputs but for the PLC.
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« Reply #21 on: November 28, 2010, 10:47:17 AM »
Yes, if I understand your question correctly, please clairify if I am not understanding what your asking.
given your example, your saying you want to turn on some OUTPUTs that would handle drive enables, across the non-plugin serial modbus correct? And you want to control that via VB? You can do it (control the Plugin-Serial-Modbus), by VB indirectly.....
Lets say you want to turn on OUTPUT1, or, even Enable1 and have it go across the pluginenabled modbus.
in VB you set, some trigger, or get some trigger, i.e. GetUserLED, or SetUserLED for example, as your input in Brians, send that result to
a termination of outputxx, and set another rung, that looks at outputxx and sends it to a Plugin enabled modbus output.
scott
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
Pages: « 1 2 3   Go Up
Print
Jump to:
