May 27, 2012, 09:58:52 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Works in progress
| | | |-+  Mach3 2010
Pages: « 1 2 3 4   Go Down
Print
Author Topic: Mach3 2010  (Read 10188 times)
Ya-Nvr-No
Active Member
Offline Offline
Scuptris 3D
View Profile
« Reply #30 on: August 10, 2011, 08:21:44 AM »
http://ftp://anonymous:guest@machsupport.com/Mach/Mach3Version3.042.040.exe
remove the http:// from the link
for some reason it gets added on.
« Last Edit: August 10, 2011, 08:23:17 AM by Ya-Nvr-No » Logged
Master of nun
Active Member
Offline Offline
View Profile
« Reply #31 on: August 10, 2011, 08:25:39 AM »
Hmmm
The manual is has dog eared pages allready!
I have homed and zeroed the z axis at the top of its travel......wait a second
back from the workshop....silly me, wasn't using machine coorinates, so had +300 instead of-300.
Thats that little problem solved!
Thanks for that Ya-Nvr-No
Thanks Gerry.
Liam
Master of nun
Active Member
Offline Offline
View Profile
« Reply #32 on: August 11, 2011, 01:39:37 AM »
I'm pretty sure now it was static from my vacuum holdown releasing back through my sensing input.....something else to sort out.
Thanks for the advice
Liam
ewidance
Active Member
Offline Offline
View Profile
« Reply #33 on: February 25, 2012, 04:10:08 PM »
Hi all,
After buying, installing, and setting up this excellent screenset, i worked with it. Really useful. I had to modify my machine (a BORCH 9060 from CNCDIY) to add optical hming switch, but it was newsworthy in. Changing tools is now easy.. and it's more clear for an old EMC2 user with that screen disposition. I'm loving it.
But... i'm french and would like to have it translated. I started to work on it, and with the help of Gerry (for giving me PSD files) french screenset and frech documentation is almost finished. Just to do the installer.
Any comments?
ewidance
Active Member
Offline Offline
View Profile
« Reply #34 on: February 25, 2012, 04:12:16 PM »
Some more screens ...
ewidance
Active Member
Offline Offline
View Profile
« Reply #35 on: February 25, 2012, 04:12:54 PM »
ANd the latest one : the excellent probing assistant.
Pages: « 1 2 3 4   Go Up
Print
Jump to:
