May 27, 2012, 09:45:12 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  specifying a coordinate - How do I
Pages: 1   Go Down
Print
Author Topic: specifying a coordinate - How do I  (Read 290 times)
California
Active Member
Offline Offline
View Profile
« on: November 23, 2010, 12:40:00 AM »
How do I type in a coordinate and hit a "go" button and the Mach3 will advance the axis to that point.  Using the up and down arrows is too difficult to be precise.
Thank You
Active Member
Online Online
Carnoustie, Scotland
View Profile
« Reply #1 on: November 23, 2010, 02:15:08 AM »
Use MDI line. Just type what you want into the MDI line then press enter on your keyboard. For example if you want to go to X100 Y100 Z2 at rapid speed you would type G0 X100 Y100 Z2  or if you wanted to go at a  feedrate of 10 you would type G1 X100 Y100 Z2 F10.
California
Active Member
Offline Offline
View Profile
« Reply #2 on: November 23, 2010, 09:23:42 AM »
Thank You Hood.
Active Member
Online Online
View Profile
« Reply #3 on: November 23, 2010, 09:27:15 AM »
No probs, have fun and double check what you type before you hit the enter key Wink
Pages: 1   Go Up
Print
Jump to:
