Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 05:49:54 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
Mach3 under Vista
Mach3 & Win7?
Pages:
1
2
Go Down
« previous
next »
Author
Topic: Mach3 & Win7? (Read 2546 times)
gummihag
Active Member
Offline
Mach3 & Win7?
on:
November 20, 2010, 05:04:36 AM »
I'm new to CNC. I just bought a 3 axis milling machine (1200x2400x200mm) from China. I am building a computer for it and wonder which OS to use. This is for personal use and the computer will be connectet to the home network (Gb lan), where all the connedtet PSs run Win7ultimate64.
Can I use Win7ultimatex86 whitout problems, or should I go for good old xp?
The machine was delivered with controller card and software package, but I havent opened it, I'm going to use Mach3 & BobCAD.
Should I use the paralell port on the PC or the chinees controller card?
I would be nice if someone bothered to safe me a lot time
Gudmund in Norway
ger21
Global Moderator
Offline
Re: Mach3 & Win7?
Reply #1 on:
November 20, 2010, 07:15:32 AM »
You can't use a 64 bit OS with the parallel port. but Win7 32 bit should work fine.
Do you have a link to the Chinese controller? If it doesn't use the parallel port, than more than likely it won't work wit Mach3.
http://home.comcast.net/~cncwoodworker/2010.html
gummihag
Active Member
Offline
Re: Mach3 & Win7?
Reply #2 on:
November 20, 2010, 07:48:22 AM »
Thakns for aswering
It's good to learn I can use Win7 32, then I can have same user interface on all my computers.
The chinees card is a PCI card whith 15 pin. I have several CDs with software (UcancamV8 and something else) and probably drivers for the card. When I look at files on the CDs there is a mixture of englis and chinees letters, and I'm somehow uncomfotable with it. I can commumicate whith the seller on email, but both being non englis speaking misunderstanding occur. Thats why I bought BobCAD and Mach3. Maby I can skip this controller card and just use the paralell port on the computer?
If you would like to see the machine it's on salecnc.com and the modell is XJ1224. They sell also controller cards, probably the same as I have.
Thanks again,
Gudmund
ger21
Global Moderator
Offline
Re: Mach3 & Win7?
Reply #3 on:
November 20, 2010, 10:48:06 AM »
The PCI card won't work with Mach3. Your best bet would probably to by a parallel port breakoutboard and connect your motors to that.
gummihag
Active Member
Offline
Re: Mach3 & Win7?
Reply #4 on:
November 20, 2010, 01:06:00 PM »
I will try that.
Thank you very much for the help Gerry.
Gudmund
Johnmorand
Holding
Offline
Re: Mach3 & Win7?
Reply #5 on:
November 21, 2010, 02:42:07 PM »
Can you run Mach 3 on a 64 bit desktop?
John
Jeff_Birt
Active Member
Offline
Re: Mach3 & Win7?
Reply #6 on:
November 22, 2010, 05:24:11 PM »
Mach itself will run on a 64 bit machine but the parallel port driver will not. So it will run on your office machine for test purposes just fine. If you want to use a 64bit OS for the CNC PC then you'll need to use an external motion control card that will work with Mach and the 64 bit OS (SmoothStepper, Kflop, etc.)
Happy machining , Jeff Birt
Check out
www.soigeneris.com
peu
Active Member
Offline
Re: Mach3 & Win7?
Reply #7 on:
November 22, 2010, 08:20:04 PM »
During most part of 2010 we've been selling CNC machines with win7-32bits to our customers, no problems reported to date, no special setups. Only thing to remember if you install it on a non shared location you will have to give permissions to the user, or run the program with admin privileges (the easiest way)
AndrewM
Support Tech
Administrator
Offline
Re: Mach3 & Win7?
Reply #8 on:
November 23, 2010, 09:22:27 AM »
Sorry, should have been more specific then a quote. After all, I run MAch3 on my Win7 64bit laptop
Thanks Jeff,
Andrew
www.machsupport.com
www.newfangledsolutions.com
MadHattan
Active Member
Offline
Re: Mach3 & Win7?
Reply #9 on:
May 21, 2012, 12:34:35 AM »
2010 thread needing a 2012 Answer... I am making my Desktop CNC from scratch. A complete DIY home build, no plans, just determination (
http://wbaldwincnc.wordpress.com
). Windows 8 will be out by the end of the year and I just can't bring myself to run a 32bit OS or WinXP for that matter, just can't, so it looks like I need an external USB/IP motion controller. I have been reading up on them, but many also have drivers that will not work in Win7 64bit. Can anyone point me to a USB motion controller that works with Win7 64bit?? One that they like and are using? Thanks!
Pages:
1
2
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
