Hello Guest it is June 09, 2026, 01:14:08 PM
Author Topic: RPM to Mach via USB  (Read 8243 times)
RPM to Mach via USB
« on: November 17, 2010, 04:28:25 AM »
I'm currently building an interface for encoders, calipers and an index sensor to get their signals into Mach via USB CDC.
Whilst the encoder part works quite well now, I'm somehow stuck on getting the index signal into Mach to show the RPMs.
On the interface I can preprocess the index signals up to the real RPM information and would be able to output the data at any stage.
However, I can't figure out, where (meaning into which SDK variable) to feed this in.
Does anybody now?
Cheers, Frank.
Re: RPM to Mach via USB
« Reply #1 on: November 22, 2010, 09:07:33 AM »
Hi Frank,
I've been searching for this a while ago. Didn't find anything, too.
Bye, Steffen
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #2 on: May 31, 2011, 05:44:50 PM »
I know it has been a while but vistacnc does make a USB tachometer that works with Mach via a plug in.
