Hello Guest it is June 10, 2026, 04:49:29 PM
Author Topic: Mach Working hours  (Read 10957 times)
Offline mrpeja
  •  114 114
    • Embroidery Machines
Mach Working hours
« on: November 16, 2010, 12:49:31 AM »
Hi guys,
I want to calculate how much my plasma table was used per month. Maybe some one has a solution?
I'll be gratefull
Mrpeja
Re: Mach Working hours
« Reply #1 on: November 16, 2010, 08:39:23 PM »
You might try the maintanance tab under operator.
Personally I use a log system. Each job that mach runs it logs the file name, date , start and finsih times. At the end of the month that file gets appended to the master log file.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #2 on: November 17, 2010, 11:01:22 AM »
Does this work?
Ian
« Reply #3 on: November 18, 2010, 10:26:16 AM »
Everything but spindle on hours. I gues Brian never turned it on in the base code.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #4 on: November 18, 2010, 12:01:38 PM »
Hmmmm - ok - but when I tried it, after a complete reset it gave me an A axis distance of several hundred - even though I don't have an A axis - nor was there any A movements in the code. It also gave me a session time of several hours even though I only ran a two minute job. And it also told me there were a couple hundred M3's even though there were only actually two - other than that I guess it was fine  ;D
Ian
« Reply #5 on: November 18, 2010, 12:52:00 PM »
Well it USED to work long ago I used to use it to track work(;-)  AS to now?????  WHO knows?
« Reply #6 on: November 18, 2010, 01:02:59 PM »
Ian I just retested here AND it all works OK except for spindle on hours. I remember Brians saying a while back he thought he did not turn that function on in the base code.
