May 27, 2012, 05:19:21 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Mach3 and G-Rex
| | |-+  G100 OEM Codes? - Please Help!
Pages: 1   Go Down
Print
Author Topic: G100 OEM Codes? - Please Help!  (Read 899 times)
AtlasMills
Active Member
Offline Offline
View Profile
« on: November 16, 2010, 12:08:23 AM »
All-
Please help- I've successfully used a G100 for basic movement for several years now, but lately I have found a need to start using more of the output pins.  I thought I would start simple and use Screen 4 to design an easy layout to manually turn on and off the 16 digital outputs, but I ran into a snag- I can't find the OEM codes to assign to the button/LEDs I want to drop into my dedicated G100 screen...  Were there special G100 OEM codes that control/monitor all the inputs/outputs of the G100, or have I missed something?!?!?  Please help!
AtlasMills
Active Member
Offline Offline
View Profile
« Reply #1 on: November 18, 2010, 08:17:55 PM »
So let me ask the question a slightly different way: The G100 has 15 digital outputs.  How do I turn one of them on/off?
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #2 on: November 18, 2010, 09:38:18 PM »
As a guess, I'd say just like any other outputs. Assign outputs to your pins, and use VB to activate them.
http://www.machsupport.com/MachCustomizeWiki/index.php?title=VB_Constants_for_Signal_Names
Pages: 1   Go Up
Print
Jump to:
