Hello Guest it is June 11, 2026, 06:31:00 PM
Author Topic: Rectangle cutout - What am I doing wrong? (or, is this a bug?)  (Read 32329 times)
« on: November 14, 2010, 12:51:00 PM »
Just purchased the Newfangled wizard and in general I'm pleased with it..
One thing that's been a bit of a nuissance, though, is the rectangle cutout wizard.
After crashing my Mach 3 several times while I waited for it to finish (after pressing make code), I realized that if I hit cancel and exit, I would get back to the Mach 3 screen and whatever code it had managed to finish would be posted..
The problem was that the wizard was starting at the correct Z and then going UP, so it never reached the correct depth (obviously) and wrote code that ran pass after pass raising the Z ad infinitum. (this happened no matter what combination of negative signs I tried out in front of both the step depth and final depth numbers)
After some debugging, I found that the problem went away if the step depth was *less* than the final depth, but if it was the same or more, then endless loop ensued.
Thanks!
-Chris
Re: Rectangle cutout - What am I doing wrong? (or, is this a bug?)
« Reply #1 on: November 19, 2010, 09:39:07 AM »
Nobody has any feedback?
So should I understand that the NFS wizards will not allow me to perform any of the profile cuts in a single pass without me editing the code?
-Chris
« Reply #2 on: November 19, 2010, 11:33:11 AM »
IF you command a G1 Z-1 move from the mdi line which way does the tool go, up or down?
« Reply #3 on: November 19, 2010, 12:42:23 PM »
If Z was at 0, it would go down.
Chris
« Reply #4 on: November 19, 2010, 12:59:53 PM »
Sorry for the delay in getting to this- I missed your original post.
It looks like you have found a bug. The preview code works OK, but the post does not. Ill get it fixed and have a new  version out soon.
« Reply #5 on: November 19, 2010, 01:51:35 PM »
OK, I found it and fixed it. See the new topic on V2.85
« Reply #6 on: November 19, 2010, 02:24:57 PM »
Thanks Ron!  I'm glad to know I wasn't going crazy.
-Chris
