May 27, 2012, 05:09:52 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Enco probe stopped working
Pages: « 1 2   Go Down
Print
Author Topic: Enco probe stopped working  (Read 585 times)
Tef9
Active Member
Offline Offline
View Profile
« Reply #10 on: November 21, 2010, 10:30:48 AM »
Ok, I think somthnig is up and its not electronic.  I have changed all the settings in the ports and pins to use either probe or input 4.  Neith work.  I examined the XML file that is stored in the C:\mach3 folder and I cant see any of the changes i have made.  Its like its not seeing the xml.
Am i looking in the right place?
A
Active Member
Online Online
Carnoustie, Scotland
View Profile
« Reply #11 on: November 21, 2010, 10:36:44 AM »
You need to look in the xml named after the profile you are using, so if you have a standard mill profile it will be called Maxch3Mill.xml If you have made a custom profile then the xml will have that name.
Tef9
Active Member
Offline Offline
View Profile
« Reply #12 on: November 21, 2010, 11:18:05 AM »
Yeh i have done that...mine is called fuente master mill.  It just does not get any of the changes.
A
Active Member
Online Online
View Profile
« Reply #13 on: November 21, 2010, 12:55:12 PM »
So when you close Mach and then Restart the settings have not taken?
Check by right clicking on the xml and choosing properties, that it is not set reaqd only.
Pages: « 1 2   Go Up
Print
Jump to:
