Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 04:57:03 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
X-Axis Motor Doesn't Start After Tool Change...
Pages:
1
Go Down
« previous
next »
Author
Topic: X-Axis Motor Doesn't Start After Tool Change... (Read 422 times)
Chet
Active Member
Offline
on:
November 13, 2010, 03:53:00 PM »
Rough cut goes smoothly until program reaches tool change pause.
After tool is changed, I press Cycle Start...
The screen in the upper right of Mach 3 indicates the tool is moving and the numbers in the X, Y, Z axis change,
BUT the X-axis motor does not move.
I've tried to reset to a previous position with the Run From Here command, but the machine also seems to have forgotten where it was.
I'm using a HobbyCNC driver board.
This is a new problem for me...
Any thoughts, suggestions???
Chet
Active Member
Offline
Carnoustie, Scotland
Re: X-Axis Motor Doesn't Start After Tool Change...
Reply #1 on:
November 13, 2010, 04:37:25 PM »
Do you move to a certain position when doing a toolchange? If you do try and move there via MDI and see if the problem exists when you try and move away again.
angel tech
Active Member
Offline
Reply #2 on:
November 13, 2010, 04:41:24 PM »
is the toolchanger driven by the x axis drive via switching, or by it's own driver.
angel tech
Active Member
Offline
Reply #3 on:
November 13, 2010, 04:44:01 PM »
that's assuming it's an auto-toolchanger?
angel tech
Active Member
Offline
Reply #4 on:
November 13, 2010, 04:47:25 PM »
scratch that, i see you're using cycle start to resume your program , so it must be a manual change.
Chet
Active Member
Offline
Reply #5 on:
November 13, 2010, 08:07:22 PM »
Thanks for replies...
I've designed a very small test program to try tomorrow.
The software that converts the bitmap into code sets up the tool change, I'm not actually writing the code.
(btw the bitmap to g-code software is the Acme Profiler)
Chet
Chet
Active Member
Offline
Reply #6 on:
November 14, 2010, 03:56:34 PM »
Happy Days! - The system is working again!
I first wrote a little program that would require a tool change.
But, most important, I also remembered that for some reason Mach3 XML programs can sometimes become corrupted.
So before running my new test code, I changed to a different version of the XML program I'd been using.
Bingo! Test program ran correctly, as did the main program when it was loaded.
The advice to make back-up XML's is good advice indeed!
However, I also did one other thing differently - I used keyboard commands rather than the mouse...
I share that info just in case it can help someone else with mysterious problems...
Chet
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
