May 27, 2012, 04:42:26 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Motors work right when windows starts up and then stop after a minute or two
Pages: 1   Go Down
Print
Author Topic: Motors work right when windows starts up and then stop after a minute or two  (Read 347 times)
dlbjcksn
Holding
Offline Offline
View Profile
« on: November 10, 2010, 10:05:07 PM »
I recently bought mach 3 and a Fireball cnc maching with motors from Probotix.  I am having trouble getting the motors to run.
If I start up windows and fire up mach 3 right away and jog the motors they run perfectly and nice and smooth.  Then after a little while they start making alot of noise and move in jerky steps.  I tried going through the windows xp setup on the machsupport website and it still acts weird.
I am running it on a desktop computer with a 1.8ghz AMD Athlon XP 2200 processor and 1GB of RAM.
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: November 11, 2010, 02:22:18 AM »
What does the driver test look like when you run it? What kernel do you have set?
Global Moderator
Offline Offline
View Profile
« Reply #2 on: November 11, 2010, 05:21:31 AM »
Post info on the motor drives  or controller you are using.
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #3 on: November 11, 2010, 11:57:23 AM »
dlbjcksn,
Is anything getting hot ?
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
Pages: 1   Go Up
Print
Jump to:
