Hello Guest it is June 09, 2026, 04:03:30 AM
Author Topic: How to change axis direction in hoss auto probe od script?  (Read 6304 times)
« on: November 09, 2010, 09:44:12 PM »
As the script starts, I start just above the center of the part less than 0.5 inch.
the tool moves to the left, Z axis drop -.5 inch, then moves farther left away form the part,
insted of right into the part to touch. Normal MaxNC 10's home to the left, my home switch
( modified ) homes to the right. So under homing and limits, it is checked for reversed axis as
needed for my setup.
Re: How to change axis direction in hoss auto probe od script?
« Reply #1 on: November 24, 2010, 07:45:26 PM »
DID you get this sorted out??? Or do you still need help?
