Hello
Guest
it is
June 12, 2026, 08:44:54 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
PoKeys
(Moderator:
NeoTO
Setting a Jog Scale
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Setting a Jog Scale (Read 10388 times)
professorburnout
25
Setting a Jog Scale
on:
November 04, 2010, 07:39:08 AM »
I am building a pendant using the PoKeys pendant as a guide. I seem to be running into the same problem that the has been posted in the past but the post ended without a answer to the poster's last question.
The jog scale changes when I am looking at the MPG flyout in Mach 3 when I change the switch but the MPG wheel still moves the axis the same amount per revolution of the MPG wheel. I am looking for a solution that the scale of movement will change for the MPG wheel when I change the scale switch.
Is this possible? Or is the scale switch just used for jogging in increments?
Paul
borisz
220
Re: Setting a Jog Scale
Reply #1 on:
November 04, 2010, 01:21:25 PM »
Hi!
As Scott (maker of the plugin) that is an user error and is in the flash help.
You have to set the mode to step jog, that is the way mach3 works.
regards
Boris
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
professorburnout
25
Reply #2 on:
November 05, 2010, 07:28:04 AM »
Thanks Boris,
When Mach3 is in step mode the multiplier switch will chance the amount the axis moves per revolution of the MPG wheel. I think I am getting confused because of my previous experience with other CNC controllers.
Paul
Print
Pages:
1
Go Up
« previous
next »
