Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 07:37:48 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
Mach3 under Vista
laptop to parallel
Pages:
1
Go Down
« previous
next »
Author
Topic: laptop to parallel (Read 1600 times)
jgalle
Active Member
Offline
laptop to parallel
on:
November 02, 2010, 05:36:47 PM »
Dear all,
I made my own 3-axis CNC-miller and its electronics. I used so far an old pc with a parallel port to connect to my interface and drivers. However it takes too much space away and I have to load the codes with a diskette (so old technology...). I would like to connect my laptop (without parallel port output).
I've seen this is a common problem and USB to parallel adapter seems not to work. One of the options I've found is a parallel PCMCIA card. However this also seems to disappear from the market and my new laptop doesnt seem to have this connector slot anymore. are there still some other solutions?
greetings
Jeff_Birt
Active Member
Offline
Re: laptop to parallel
Reply #1 on:
November 04, 2010, 12:59:18 PM »
If you want to use a laptop then a SmoothStepper, DSPMC, kFlop motion control boards are your best bet. I carry the SmoothStepper:
http://www.soigeneris.com/SmoothStepper-details.aspx
and have used them in many controls.
Happy machining , Jeff Birt
Check out
www.soigeneris.com
jgalle
Active Member
Offline
Reply #2 on:
November 04, 2010, 05:02:44 PM »
the problem is that I am such an a**hole that wanted to make his machine completely by hand (to get some practical experience and more insight in mechanical technics)... So I refuse to by such thing (at least for this project)
http://www.megaupload.com/?d=VC12ALIQ
is what I mean (some photos of the machine)
Edit: RC
Last Edit: November 04, 2010, 05:26:08 PM by Overloaded
dar303
Active Member
Offline
Reply #3 on:
November 05, 2010, 01:50:06 AM »
This is from the Mach3 specifications:
" * Desktop PC (if using the Mach3 Parallel Port Driver - laptops are not supported because the power saving features of the chipsets disrupt the pulse stream, PCMCIA and USB parallel adaptors will *not* work.)"
An external card is mandatory with a laptop.
jgalle
Active Member
Offline
Reply #4 on:
November 06, 2010, 09:08:19 AM »
what is meant with "an external card"? is that the Smoothstepper?
thanks for the clarification (too bad that it is not that good news) maybe i find other software that gets the job done?
Jeff_Birt
Active Member
Offline
Reply #5 on:
November 06, 2010, 09:32:09 AM »
It is not a SW issue, it is a HW issue. Laptops are built to save power so they adjust the processor speeds among other things to do that. When you need precise timings, as Mach does, then that will not work. If you want to use a laptop then you need to use an external motion controller.
Check out
www.soigeneris.com
dar303
Active Member
Offline
Reply #6 on:
November 07, 2010, 05:21:29 PM »
exactly, an external hardware takes care of the critical timing and keeps the motors running smooth!
Global Moderator
Offline
Reply #7 on:
February 18, 2011, 07:03:10 AM »
At our end we have probably tried 10 laptops. I personally have use an old dead dog NEC which had a PP port and it worked perfectly fine.
All the Dell laptops ( about 5 or so ) didn't work well . The Tashiba one was junk fro CNC. A friend uses a Dell laptop and it works fine but he also made a circuit to refine the pulse from the PC. So you just don't know.
I use a dedicated PC for CNC and it is not a laptop.
The SS sits on the shelf gathering dust ( no backlash and there probably never will be in my opinion).
dar303
Active Member
Offline
Reply #8 on:
February 18, 2011, 07:58:24 AM »
If you are not using the Smoothstepper I could buy it from you cheap for my next machine! Or maybe trade for something?
Smootstepper has its quirks but work very well iin my application.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
