May 27, 2012, 07:36:42 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Touch screens
Pages: 1   Go Down
Print
Author Topic: Touch screens  (Read 2400 times)
boblee
Active Member
Offline Offline
View Profile
« on: November 02, 2006, 04:43:51 PM »
Hi guys what would be the easiest  and cheapest touch screen to implement  on my router would you use an industrial model like a Siemens or
Allen Bradley or is there something else more in the lines of  a commercial touch screen?
Thanks  Bob
« Last Edit: November 02, 2006, 04:47:23 PM by boblee » Logged
Graham Waterworth
Administrator
Offline Offline
West Yorkshire, England
View Profile WWW
« Reply #1 on: November 02, 2006, 05:13:19 PM »
I use a CTX PV500T
Graham.
« Last Edit: November 02, 2006, 05:15:23 PM by Graham Waterworth » Logged
G-Code is on the cutting edge
Autovalues Engineering, CNC machining specialists, Bradford, England
zealous
Active Member
Offline Offline
View Profile WWW
« Reply #2 on: November 02, 2006, 07:34:48 PM »
I have mine in a climate controlled environment and I don't use hazardous material, so any touch screen should do.
I bought a USB 19" touch screen on ebay for $250.00. Just make sure how it hooks up to your computer, they have alot of serial port connection ones.
Regards, Jason Blake
www.Fusioncnc.com
Guest
« Reply #3 on: November 03, 2006, 03:25:07 PM »
I have a converted 17 inch sycmaster on my mill and have just got an ELO 17 inch kiosk screen, the ELO is much more accurate than the syncmaster.
Pages: 1   Go Up
Print
Jump to:
