May 27, 2012, 07:20:37 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Motherboard Recommendations
Pages: 1   Go Down
Print
Author Topic: Motherboard Recommendations  (Read 455 times)
obwolfe
Holding
Offline Offline
View Profile
« on: October 31, 2010, 02:25:21 PM »
I have exhausted Google, looking for recommendations for a low end motherboard to build a Mach3 control PC. It needs to have enough power and RAM to run Mach3 on top of Windows 7.  I have always used Asus and Gigabyte motherboards in the past for other applications.  Low-end boards I have considered are:
- Gigabyte - GAM78LM-S2H
- Asus 0 M4A785-M
Any suggestions/recommendations?  Thanks in advance for your help.
Brock
edvaness
Active Member
Offline Offline
View Profile
« Reply #1 on: November 01, 2010, 06:23:16 PM »
Any mobo with 2ghz processor and 1gb ram will do fine for mach, for win7.
Xp requires less, I'd go the xp route.
Ed VanEss
docltf
Active Member
Offline Offline
View Profile
« Reply #2 on: November 01, 2010, 09:39:30 PM »
i just got one of these from tiger direct.so far so good.
asus m2n68-am plus      price 54.99
bill
TOTALLYRC
Active Member
Offline Offline
View Profile
« Reply #3 on: November 01, 2010, 11:57:05 PM »
If you are using an external motion controller you don't need a lot of power. I am using a 1ghz with 512 ram with Win7 and it works great. It is an old Compac deskpro en SFF.
 I only use it to run the mill.
I have an E-machines 2+ ghz that I run the router on thru the Pport and it passed the driver test up to 100khz. XP
Was a freebie from a friend.
Nice to have friends.
Mike
SDConcepts
Active Member
Offline Offline
View Profile
« Reply #4 on: November 02, 2010, 12:12:50 PM »
I had problems with an Asus board that had an Nvidia video chipset and driver.  i switched to gigabyte with the intel video chipset and driver all seems to be good.
TramAlot
Active Member
Offline Offline
View Profile
« Reply #5 on: November 02, 2010, 12:24:36 PM »
msi for both amd and intel platforms, easy setup and cheap (er). tiger direct
Pages: 1   Go Up
Print
Jump to:
