Hello Guest it is June 10, 2026, 07:13:05 PM
Author Topic: Mach3 closed loop speed control  (Read 8322 times)
« on: October 30, 2010, 01:40:53 AM »
I'm trying to help a friend who has a CNC machine.
He wants to use the Mach3 closed loop speed control to control the speed of his router.
I know very little about Mach3 - I'm giving him advice on the electronics issues.
Could someone please point me to a description of what type of feedback signal the Mach3 PWM speed control needs.
I assume it is pulses derived from an optical shaft speed detector.
Also, how is it connected to the computer?
I have a copy of Mach3Mill_Install_Config.pdf but it lacks detail on the speed control function.
Any advice will be appreciated.
Re: Mach3 closed loop speed control
« Reply #1 on: October 30, 2010, 03:34:05 AM »
Afraid I know nothing about the PWM type speed control in Mach as I use Step/Dir with Servos. Having said that the only feedback to Mach for any spindle speed monitoring is a single pulse per rev that you input via the Index input.
« Reply #2 on: October 30, 2010, 03:24:38 PM »
Thanks Hood,
That gives me a clue as to what to look for.
