May 27, 2012, 07:06:25 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Mach3 XML profile for G540 and THC301D
Pages: 1   Go Down
Print
Author Topic: Mach3 XML profile for G540 and THC301D  (Read 750 times)
streetbikedepot
Active Member
Offline Offline
View Profile
« on: October 29, 2010, 07:09:59 PM »
I've been using the G540 XML but now that I've bought a THC301D it is provided with a new XML.....which one do I use, are there G540 specific changes that I need to make within Mach 3 if I use the new XML for the torch height control?  I havent installed the THC yet, I just wanted to be ahead of the game if I had problems.
streetbikedepot
Active Member
Offline Offline
View Profile
« Reply #1 on: October 29, 2010, 07:28:20 PM »
I think what I need to know is wether I can combine the two profiles without having to manualy set up my ports and pins.
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #2 on: October 30, 2010, 03:36:48 AM »
No, you will have to enter the values specific to your machine if the xml you are loading is different.
Pages: 1   Go Up
Print
Jump to:
