Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 06:47:05 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Z-axis problem
Pages:
1
Go Down
« previous
next »
Author
Topic: Z-axis problem (Read 725 times)
dglasco
Active Member
Offline
Z-axis problem
on:
October 25, 2010, 10:01:30 PM »
Last summer I built a home CNC machine for use in my garage. orig ionally I built and assembled a home made z-axis assembly. I could never get the z-axis to operate over 20-inches per min compared to the x&y axis which could operate at near 50-inches per min. I scraped the home made z-axis assembly and went with a K2 CNC prefabbed assembly rated at 100 inched per min. I still cannot get the z-axis to exceed 25-inches per min.
Other than that problem my machine works great and my tolerances are acceptable for the type of wood working I am doing. I purchased the stepper motors and 3-axis controller from Xylotex. Is there a setting in the Mach3 software I need to check?
Sorry for the lack of pictures, I will try to get some posted shortly.
Dglasco
Active Member
Offline
Carnoustie, Scotland
Re: Z-axis problem
Reply #1 on:
October 26, 2010, 02:14:32 AM »
Are the steps per unit for the Z axis a lot more than the other axis?
dglasco
Active Member
Offline
Re: Z-axis problem
Reply #2 on:
October 26, 2010, 10:14:55 PM »
Yes the X & Y axis are set at 3200 and the z axis is set at 16000.
I have 1/2" 2 or 4 start threaded rods for the X & Z axis and 1/2" single start rod for the z axis
any suggestions would be greatly appreciated.
Right now it cuts and travel accurately but slowly.
Active Member
Offline
Re: Z-axis problem
Reply #3 on:
October 27, 2010, 02:36:49 AM »
Ok well I wa thinking maybe the kernel was set to low for your steps per unit on the Z but that is not the case as even at 25KHz kernel you could theoretically get a rapid speed of 375IPM.
Ok so now thats been ruled out what are the actual problems when you try and set faster?
It could be that your pulse stream is extremely bad and as such 7KHz is the max you can reliably output, have you run the driver test to see what it looks like?
dglasco
Active Member
Offline
Re: Z-axis problem
Reply #4 on:
October 27, 2010, 04:05:35 PM »
When I try to run the machine faster than 25 ipm the z-axis stepper motor will intermittently pause or just stop (almost like it is hanging up on something) while the program is trying to tell the stepper motors to lower or raise the router and it screws up the depth of cut on my machine.
How do I check my pulse stream? Is there a diagnostic I can run using the mach3 software?
Active Member
Offline
Re: Z-axis problem
Reply #5 on:
October 27, 2010, 04:38:59 PM »
Yes, close Mach and go to the mach folder, you will see a file called drivertest.exe double click that and let it run and see what the line in the graph looks like.
What kernel speed do you have Mach set to?
dglasco
Active Member
Offline
Re: Z-axis problem
Reply #6 on:
October 28, 2010, 06:27:48 AM »
Results of Driver Test you requested
The graph is pretty much a straight line and it said system excellent.
Pulses 24999
CPU Mhz 2940
short time 34.483 varies
long time 47.271 varies
Apic time constant 5346
Interupt 0
Max. Variation 12.709 varies
Version 550
PCI second lo 3579545
PCI second Hi 0
Window 1 second 2940000000
Avgerage interupt 40.0030 varies
Long Interupt 66.214 varies
dglasco
Active Member
Offline
Re: Z-axis problem
Reply #7 on:
October 29, 2010, 06:24:01 AM »
I tried playing with my motor tuning yesterday in Mach3. The fastest speed I could obtain without the z axis hanging up was 25 IPM. If I set it at 26 IPM I would start having problems.
I think I need to change my lead screw with a 2 or 4 start.
Active Member
Offline
Re: Z-axis problem
Reply #8 on:
October 29, 2010, 06:28:16 AM »
Sorry must have missed your driver test reports
If you look on the diagnosics page in Mach what is the frequency at and is it varying quite a bit?
What do you have the kernel on Ports and Pins main page set to?
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
