Hello Guest it is June 09, 2026, 12:01:44 AM
Author Topic: Mach & windows7  (Read 11060 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Mach & windows7
« on: October 24, 2010, 05:28:30 AM »
Don't know if I've missed it somewhere but what's the state of play re: windows 7 and Mach?
Ian
Re: Mach & windows7
« Reply #1 on: October 24, 2010, 05:48:02 AM »
There are some threads in the  Mach and Windows Vista forum. Appears to run fine in 7.
Offline stirling
  •  2,188 2,188
  • UK
Re: Mach & windows7
« Reply #2 on: October 24, 2010, 06:10:00 AM »
Thanks Gerry
Offline kcib
  •  74 74
Re: Mach & windows7
« Reply #3 on: October 24, 2010, 06:46:21 AM »
Have been running Windows 7 for some 9 months without any problems whatsoever ,
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Mach & windows7
« Reply #4 on: October 24, 2010, 10:18:23 AM »
If you want to use the parallel port driver stick with the 32bit version of Win7. The parallel port driver will not run on a 64bit OS. If you want to use a SmoothStepper or other external motion control board than the 64bit version is fine. (I know the SS works fine on Win7-64.)
Happy machining , Jeff Birt
Offline stirling
  •  2,188 2,188
  • UK
Re: Mach & windows7
« Reply #5 on: October 24, 2010, 10:24:58 AM »
Thanks Alan
Thanks Jeff - It'll have to be the PP driver because this is a plasma setup with THC so as I understand it the SS is a non-runner - is that correct?
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Mach & windows7
« Reply #6 on: October 24, 2010, 10:40:37 AM »
Right. The SS does not do THC at this time.
