Hello Guest it is June 09, 2026, 03:24:44 PM
Author Topic: Wierd port addresses  (Read 7501 times)
« on: October 23, 2010, 10:49:38 AM »
After battling the 64 bit OS issues I decided to take the computer back to the seller. I retasked my 6 year old XP 32 bit machine to run my plasma/router. I pulled the ports from the dead machine and installed into the old machine with XP sp3. Installed Mach, ran the driver test and got a "excellent". :) Now I was going to feed my old xml files in and I noticed the two port addresses are different looking. The old addresses were a hex address xab0 or something like that, the new are 9400 and 9800. I double checked using the "Get port address" file in Mach. I haven't hooked it to the CNC machine yet. Does that sound right or does  XP SP3 do something different with addresses?
Thanks Much,
Mike
Re: Wierd port addresses
« Reply #1 on: October 23, 2010, 01:38:14 PM »
Try and see would be the simplest answer, I have seen all sorts of weird and wonderful looking addresses.
« Reply #2 on: October 25, 2010, 06:27:23 PM »
These wierd numbers would not work, I pulled the cards reinstalled 1 card at a time and got more "normal" looking addresses and it fired right up.
Mike
