Hello Guest it is June 10, 2026, 02:32:56 AM
Author Topic: Huge Threading Problem Help  (Read 60960 times)
Re: Huge Threading Problem Help
« Reply #50 on: March 21, 2011, 02:16:55 AM »
Sorry Tom, not quite sure what you are meaning, is it all fine now?
Offline TomS
  •  17 17
« Reply #51 on: March 22, 2011, 10:05:37 AM »
Hello Hood,
well almost, I would say.
I turn on the frequency controller by hand. While running, the correct speed is displayed, but when i stop the spindle, run out of the spindle shows the last value to slow even at standstill. I hope you understand what I mean, my English is a little rusty. But Threading is always o.k. Only the continued displayed low Spindle Speed, for exampel 125 1/min is an irritation...at standstill.
Greetings, Tom
« Reply #52 on: March 22, 2011, 10:08:03 AM »
Did you tell Mach the spindle was stopped by calling M5 in code or MDI or by pressing the spindle button on the screen?
Offline TomS
  •  17 17
« Reply #53 on: March 22, 2011, 11:27:30 AM »
That makes no difference.
Tom
« Reply #54 on: March 22, 2011, 11:32:02 AM »
Can you attach your xml please and I will see if I can replicate it
Offline TomS
  •  17 17
« Reply #55 on: March 22, 2011, 12:49:11 PM »
Here Comes (after updating on last Rev)
Tom
« Reply #56 on: March 22, 2011, 02:08:44 PM »
Tom I am just simulating here with the index pulse but if I command a spindle speed or press the spindle button the S True DRO shows the value equal to the pulses I am simulating. When I stop the spindle or command  a M5 the S True DRO returns to zero, so afraid I do not know why it does not do that for you.
Only thing I can think of is you are meaning the commanded spindle speed DRO is staying at the last commanded speed. If that is what you mean then that is normal and I think it has always been that way. If you want that to zero then you could alter the M5 macro to zero it.
Offline TomS
  •  17 17
« Reply #57 on: March 26, 2011, 05:17:26 AM »
Hello Hood,
at the DRO is the latest average of the last spindle rotation bevore stopping. You realize well, if the spindle rotates slowly by hand, changes the DRO accordingly, but never returns back to 0 at stopping.
It shows, as the DRO ist "waiting" on the next Index Impulse.
Not Nice, but threading works.
Greetings, Tom
« Reply #58 on: March 26, 2011, 08:46:43 AM »
I dont know what to suggest, the DRO goes to zero for me (with your xml) if I tell Mach the spindle has switched off, ie press the button on screen to turn off, have code call a M5 or call a M5 from MDI.
« Reply #59 on: March 26, 2011, 10:05:48 AM »
Toms,
I would suggest you create a new xml.
I couldn't get my spindle rpm to display in the DRO no matter what was tried with your xml from reply #55.
