May 27, 2012, 06:11:35 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  4th Axis move after feed hold
Pages: « 1 2   Go Down
Print
Author Topic: 4th Axis move after feed hold  (Read 799 times)
Doorn
Active Member
Offline Offline
View Profile
« Reply #10 on: November 17, 2010, 03:07:07 PM »
Hi Hood,
You are really digging into it i see, thanks a lot.
I don't have  brains running.
The macropump i programmed myself, I'm sure i did not program movements in it, but maybe something triggers it.
What i find strange is that the A-move is synchronised with the finishing of the interrupted move of the other axis.
To make this happen there should be some intelligent programming involved which certainly wasn't me  Wink
I will test what it does without macro and plug-in as soon as the axis is free again.
Regards
David
Doorn
Active Member
Offline Offline
View Profile
« Reply #11 on: November 21, 2010, 01:30:44 PM »
I hate it when this happens Angry
I wanted to test if it was the macro or plug-in and now i can not reproduce the problem anymore.
I didn't turn off anything yet and used the same test file but the 4th axis does not rotate anymore like before.
Nice if it is gone, but will it return and when Huh and i still don't know what caused it.
For now i think i will remain very cautious using the feedhold.
Many thanks to those who tried to find a cause / solution.
If the problem reappears I hopfully find what triggers it too.
Regards David
Pages: « 1 2   Go Up
Print
Jump to:
