Hello Guest it is June 09, 2026, 10:32:20 AM
Author Topic: Step / Velocity mode  (Read 36729 times)
Offline DMBGO
  •  201 201
  • Time is the same in a relative way
Re: Step / Velocity mode
« Reply #20 on: October 21, 2010, 02:05:20 AM »
Hi Hood,
That was good timing, I just connected a spare mpg to the PP, just about to try it. back in a few mins
David
Offline DMBGO
  •  201 201
« Reply #21 on: October 21, 2010, 02:27:21 AM »
Right, I've tried it with an MPG connected directly to the PP without the smooth-stepper enabled and things are just the same, so it doesn't look like the smooth-stepper is affecting the results.
I even recalibrated the MPG and set the max speed and step / velocity change over to 1000 detents / sec, to ensure that it would be stepping if it was going to, and it didn't, it just ran in velocity mode.
It was quite smooth, probably a fair bit smoother than the serial mpg, but that's probably to be expected.
Not sure where to go from here, perhaps into the house for a cuppa? :)
David
Offline DMBGO
  •  201 201
« Reply #22 on: October 21, 2010, 02:30:08 AM »
BTW Hood, if you want to put your video back, I can watch it this evening, but don't go to any trouble.
David
« Reply #23 on: October 21, 2010, 12:57:16 PM »
Sorry not been at the workshop today, that is where the vid is. If I remember tomorrow I will repost it.
If possible it might be better to connect your MPG via Port3 of the SmoothStepper.
« Reply #24 on: October 22, 2010, 04:47:10 AM »
Afraid I had deleted the vid from the computer here at the workshop so made another one and uploaded it. Let me know when you have seen it and I will delete.
http://www.youtube.com/watch?v=5gIKfSsgFE4
Offline DMBGO
  •  201 201
« Reply #25 on: October 22, 2010, 07:17:00 AM »
Thanks Hood,
Your axis are definitely a fair bit smoother than mine. I think I'll try your suggestion and hook the mpg up to port 3 on the SS. I appreciate you going to the trouble.
I am still mulling over the step jog thing, I would have dropped it if Ray hadn't said he had it working.
Ray, if you read this, what version of Mach are you running?
David
« Reply #26 on: October 22, 2010, 07:32:01 AM »
I have servos on my machines with fast acceleration and that actually makes it slightly less smooth when at slow speed in Vel mode. The Bridgeport has steppers and accel is a lot slower but the MPG is smoother at slow revs, then again if it was to be used for manual machining I would remove the detent from the MPG as that would help keep a more consistent slow turning speed.
« Reply #27 on: October 22, 2010, 08:44:09 AM »
Thanks Hood,
Dave,
I'm using 3.042.020, with a SmoothStepper.
