Hello
Guest
it is
June 10, 2026, 09:13:10 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
z axis moving to far
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: z axis moving to far (Read 7735 times)
cairo2nz
21
on:
October 18, 2010, 07:13:31 PM »
Hi there,
First posted this in wrong place in Turn.
I have a small problem that is probably my own doing but I can't see how to correct it.I can be cutting wooden gears or any other profile fine for a few days, then for some reason next time I try to start the Z axis runs to max plus. Nothing I do will stop it running to max.After messing around with mach3 for ages it will start behaving itself but I don't know why. Can anyone suggest what I am overlooking and how to correct problem. I am not all that familiar with mach3 as yet.
Bernie Byers
Tweakie.CNC
9,356
Super Kitty
Re: z axis moving to far
Reply #1 on:
October 22, 2010, 02:18:36 AM »
Hi Bernie,
I am just guessing here but if, for example, your Z Axis has not been correctly zeroed before you start (Z Axis DRO) then this may happen. Another reason is 'safe Z' enabled (config/safe z setup) which could be incorrectly setup.
Carnoustie, Scotland
Reply #2 on:
October 22, 2010, 02:36:17 AM »
When the axis is going wrong can you jog in both directions? If not then sounds like a bad connection on the Z Dir wiring.
Print
Pages:
1
Go Up
« previous
next »
