Hello Guest it is June 09, 2026, 08:01:03 AM
Author Topic: punching holes  (Read 9175 times)
punching holes
« on: October 05, 2010, 01:34:43 PM »
is there a way to get bobcad or mach3 to punch holes instead of drilling?
Ron Hess
Re: punching holes
« Reply #1 on: October 05, 2010, 02:23:40 PM »
Could easily get Mach to do that as all you would need to do is command a rapid Z move but as for making the code in BOBCAD, afraid I dont have a clue as I have never used it.
Offline ASC
  •  59 59
    • Automation Systems
Re: punching holes
« Reply #2 on: October 05, 2010, 03:12:56 PM »
I tried  using mach for punching holes in foam but I was using an air solenoid controlling a linear slide to control the punch (annular cutter really) held in a collet.   Just a simple X/Y table with a brain that fired the output to the solenoid every time the Z DRO was less than zero, and retracted the solenoid when Z was greater than zero.  Worked pretty well actually but I ended up going to a heated cutter.
Mr. Creosote
Re: punching holes
« Reply #3 on: October 08, 2010, 08:20:20 AM »
ASC
i would like to use a air cylinder to pierce light tin. what type on control valve are you using? i am new at this cnc so all the help you can offer would be a great help. is there any examples of how punching is accomplish? you mention to use brain,what is this and how would i use it?
Ron Hess
Offline ASC
  •  59 59
Re: punching holes
« Reply #4 on: October 08, 2010, 02:15:03 PM »
I just used a 24volt smc solenoid to fire the actuator down.  The actuator has a spring return.
Brains are similar to plc ladder logic, you give them a set of input conditions that control various outputs.  Check out the Mach tutorial videos for more info on how to set them up.
My brain acted something like this:
If Z = Less than zero then turn relay output 1 on
If Z = Greater than zero then turn relay output 1 off
Mr. Creosote
