Hello Guest it is June 09, 2026, 09:10:27 AM
Author Topic: Very bad issue with a .nc file  (Read 7609 times)
« on: October 04, 2010, 11:46:05 AM »
Hello,
I just had a crash in my machine, when I loaded and ran the file attached.
When I load the file, I get a "out of limits" warning. Which definitely can't be the case, because the files limits are at about 1700mm. I set machine limits to +/-3000mm.
What happens is: The first axis command is a Z1.5, to lift the tool above the detail. Now Z does not lift 1.5mm, but ... I don't know how far (some cm at least) because I have to emergency stop it.
The z-gauge on the screen is counting correctly, but the axis is getting way more pulses, like if the steps/unit value would have been changed by factor 10. Checked this one: It is still set to the old value.
If I use a different file with a smaller part which is identical up to the point where the Z1.5 command appears: No issue.
If I run the (bad) file in CNC Simulator: No issue.
I am using R3.042.029 and I am not sure whether an update helps.
Anyone an idea except "try it out" :-))
Thank for helping out
Re: Very bad issue with a .nc file
« Reply #1 on: October 04, 2010, 12:11:30 PM »
Your code has a G20 at the start which means its in inches, so when it asks for a 1.5 move that is 1.5 inches and not mm, ie 25.4 times bigger.
« Last Edit: October 04, 2010, 12:18:52 PM by Hood »
« Reply #2 on: October 04, 2010, 12:55:38 PM »
Damned...one beer for you. I must have been blind. Too much work...
« Reply #3 on: October 04, 2010, 02:13:46 PM »
LOL, it happens to me as well and often more than I care to admit ;)
