May 27, 2012, 02:17:54 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  dspMC/IP Motion Controller (Moderator: vitalsystem)
| | |-+  Fixture Offsets
Pages: « 1 2 3   Go Down
Print
Author Topic: Fixture Offsets  (Read 1752 times)
egerber
Active Member
Offline Offline
View Profile
« Reply #20 on: October 06, 2010, 07:10:25 PM »
Sure it can't hurt
I will post results in the morning
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #21 on: October 06, 2010, 07:12:28 PM »
Ok, hopefully the issue can be found by all this testing, certainly have never seen anything like that here.
egerber
Active Member
Offline Offline
View Profile
« Reply #22 on: October 07, 2010, 12:13:08 PM »
Thank every one for your input
Here is the scenario
Did nothing to Y axis configuration
changed config to Ignore Tool Change
Added M1 to stop program between tool changes (every thing runs perfect)
Changed M1 to M0 to eliminate the possibility of optional stop being turned off and crashing the tool (same results)
Pryor to those changes
I fount that if a axis moved in the wrong direction you can open the Save fixture page select X save Y save then restart the tool and every will run correctly
Will advise if any thin changes
Active Member
Offline Offline
View Profile
« Reply #23 on: October 07, 2010, 01:42:39 PM »
Thats good news in as much as you can now run OK.
Can you attach the M6 macros, maybe there is something in them that is affecting things.
Pages: « 1 2 3   Go Up
Print
Jump to:
