Hello Guest it is June 09, 2026, 05:30:29 PM
Author Topic: TAIG 3000 DSLS  (Read 27595 times)
TAIG 3000 DSLS
« on: September 26, 2010, 07:35:30 AM »
First of all hello to all comunity members and great wishes my name is Shmuel and i jeweler and i just bay new mill for my shop its taig 3000 dsls with lin engineering motors 4 axis first off all all the axis work find for correct 3 of them but z axis do some problem i always have limit switches estop i dont have this hardware upgrades sow i understand its somthing in mach3 i try to off the z axis limits in input but so z axis not jog i realy stuck and dont know what to do please help guys with you litle help i am sure we can do it i just upload my xml if you can look i need to work in mm thanks for you help guys ???  ??? ???
Re: TAIG 3000 DSLS
« Reply #1 on: September 26, 2010, 07:53:28 AM »
if it important i use 220v transformer to 110v with 50hz
Re: TAIG 3000 DSLS
« Reply #2 on: September 26, 2010, 08:30:55 AM »
Have a look on the diagnostics page and see if the LED for the Z Limit is active, if it is then press the switch and see if it goes out.
Re: TAIG 3000 DSLS
« Reply #3 on: September 26, 2010, 12:20:06 PM »
no in diagnostic everything off
Re: TAIG 3000 DSLS
« Reply #4 on: September 26, 2010, 03:17:42 PM »
You may be picking up noise then, try setting a Debounce Interval of 2000 and see if that helps, if it does reduce it to as low as you can get. You will find the Debounce Interval from Config menu then General Config page, its top right hand side.
Re: TAIG 3000 DSLS
« Reply #5 on: September 26, 2010, 03:18:51 PM »
thanks i go try this
Re: TAIG 3000 DSLS
« Reply #6 on: September 26, 2010, 03:23:07 PM »
no its not working i have this problem only in z++ in z--all ok
Re: TAIG 3000 DSLS
« Reply #7 on: September 26, 2010, 03:26:01 PM »
Is it soft limits that you are having a problem with?
What exactly happens?
Do you see any messages in the ticker window at the bottom of the screen?
Re: TAIG 3000 DSLS
« Reply #8 on: September 26, 2010, 03:28:59 PM »
 i just try jog the z axis up + and every cuple lines its stop limit switches trigered this is the mesage i see down of the screen nad yes the limit switches just crazy me i real dont know what to do other axis just work fine
Re: TAIG 3000 DSLS
« Reply #9 on: September 26, 2010, 03:32:53 PM »
Ok as a test disable the Z limit switch in Ports and Pins Inputs page and see if you can jog fine. Be careful though as you will not have a limits switch so dont get too close to the end of the Z axis.
