May 26, 2012, 11:03:31 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Referance button
Pages: 1   Go Down
Print
Author Topic: Referance button  (Read 301 times)
Captain Midnight
Active Member
Offline Offline
View Profile
« on: September 22, 2010, 02:58:09 AM »
I'm trying to home my machine. When I hit the referance button nothing moves. Does it need to be set up some how to operate? If I enter G28, the table moves to the center, and not to the home switches. I watched the tutorials on homing and I think I have everything set right. I must be missing something. I'm hoping someone can shed some light.
Thank you
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: September 22, 2010, 03:26:11 AM »
Sounds like you dont have the home switches enabled in Ports and Pins, Inputs. Only other explanation I can think of is the active state of your home switches are the wrong way so Mach thinks they are already active so wont home, you should however get a message in the ticker window at the bottom of the screen informing you of that.
Captain Midnight
Active Member
Offline Offline
View Profile
« Reply #2 on: September 22, 2010, 12:06:55 PM »
Home switches are enabled in ports and pins, tried active high and active low. No message. Referance button does nothing.
Active Member
Offline Offline
View Profile
« Reply #3 on: September 22, 2010, 01:17:52 PM »
Seems like you may have a bad screenset as that is the only explanation I can see for both this and your other problem.
Captain Midnight
Active Member
Offline Offline
View Profile
« Reply #4 on: September 22, 2010, 04:48:43 PM »
What is the fix for that? I don't know what a screenset is.
Pages: 1   Go Up
Print
Jump to:
