May 26, 2012, 10:58:55 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Newfangled Solutions Wizards (Moderator: Ron Ginger)
| | |-+  Array wizard?
Pages: 1   Go Down
Print
Author Topic: Array wizard?  (Read 1337 times)
turmite
Active Member
Offline Offline
View Profile
« on: January 19, 2006, 12:41:53 PM »
Hi Brian,
I have not tried the wizards yet as I am still using Mach2. I'm in the beginning stages to make the change and one option I think would be neat, and you may already have it, is an array wizard. I know this can be done in gcode somehow, but I started out with a system that had a fill in the block array wizard that was so quick it was just a pleasure to use.
Off topic but I thought you might enjoy it. I need a wizard that can read my mind and get the machine to produce what I see in my mind! I make gunstocks and I can see what I want, but to get it into Rhino and then to the machine is a different story! It never looks like what I see! So when you get the time do a "gunstock wizard" Grin
Mike
« Last Edit: January 19, 2006, 12:43:34 PM by turmite » Logged
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #1 on: January 19, 2006, 02:25:11 PM »
There is an Array wizard that Art made, I have not used it but I think we can figure it out <G>
The wizard to read your mind... hmmmm what are you tinking about using to get the data out of your head??? Smiley
Fixing problems one post at a time Wink
www.newfangledsolutions.com
www.machsupport.com
turmite
Active Member
Offline Offline
View Profile
« Reply #2 on: January 20, 2006, 07:43:36 PM »
Brian it is hard to extract from a vacuum! The array will do for now! Wink
Mike
Pages: 1   Go Up
Print
Jump to:
