Hello Guest it is June 10, 2026, 07:48:38 AM
Author Topic: Wanted: Position X & Y at the Center of a Hole Macro  (Read 17386 times)
« on: September 20, 2010, 11:45:10 PM »
I have seen a lot of talk about center finding and it all seems to boil down to finding the Z height and bug fixing... Is there a direct  posting of a working  macro, for Mach3, that will find the center of a drilled hole? I need to reliably find the center of a hole that has been drilled in a metal material for rework. The electric touch sensor can be positioned to fit in the hole without touching the sides as a starting point. Trying to read hundreds of pages of commentary with hundreds if external thread references is a bit much.
Bill
Pixel Tamer
Re: Wanted: Position X & Y at the Center of a Hole Macro
« Reply #1 on: September 21, 2010, 02:12:59 AM »
If you need accuracy, I'd use a dial indicator held in the spindle chuck.
« Reply #2 on: September 21, 2010, 06:41:30 AM »
This comes from the hoss website
Hope this help.
Jeff
« Reply #3 on: September 22, 2010, 08:42:52 AM »
The files are very useful.
I noticed that if the 'Machine Coordinates' button happens to be pressed, strange things happen. I need to find how to determine that button is ON so I can force a warning message.
Thanks again,
Bill
Pixel Tamer
« Reply #4 on: September 22, 2010, 09:57:12 AM »
Thanks again,
Bill
Something like this at the start of the macro should do it.
If GetOemLED(16) Then
MsgBox("Machine Coord's Active, change and restart macro")
End
End If
« Reply #5 on: September 23, 2010, 12:28:43 PM »
Hood,
OEMLed(16) did the trick. I Found this solution works well. I used an ElseIf and posted the message in the status window. That way the process is automatically terminated on this error condition. Added it as follows:
If GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty
    Code "(Probe is grounded, check clearance and try again)"
ElseIf GetOemLed (16) <> 0 Then 'Warning Wrong Coordinate system
    Code "(Center Finder Error: Exit Machine Coordinate Mode)"
Else
 (Body of the code)
I added a second pass at finding the center of the X axis, because I didn't trust the probe to give me good results if it starts out next to the Y edge of a hole. Once the near X axis center is found, the probability of a clean touch goes way up. The process now searches for X, then Y, then X again, done. On several practice runs, I noticed that the X center moved a few thousandths on the second pass, but never by more than 0.001 on a search starting from the near center of the circle. This is well within the slop of the CNC machine.
Bill
Pixel Tamer
« Reply #6 on: September 23, 2010, 01:46:07 PM »
The other way you could do it is if in Machine coords you could change it from the macro rather than aborting.
« Reply #7 on: September 23, 2010, 03:59:11 PM »
If you don't like reinventing the wheel, you might be interested to know that circular hole center finding is a built in feature of MachStdMill's probing support.
Drop over to the MSM forum for more info.
http://www.machsupport.com/forum/index.php/topic,15291.0.html
www.CalypsoVentures.com
