Hello
Guest
it is
June 10, 2026, 05:14:43 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Imperial to Metric
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Imperial to Metric (Read 13466 times)
CJCNC
24
Imperial to Metric
on:
September 20, 2010, 07:55:53 AM »
Hi Guys,
I created a drawing in metric and made an NC code for it.
I have my machine setup in Inches. When I bring in the NC code, I switch to Metric on the setup page. Everything seems to work well except that when I set my work zero it reverts back to Inches.
I tried changing the main units to metric and re-tuned my motors accordingly.. However, it still does the same thing. I'm confused
Any help is appreciated
angel tech
499
Re: Imperial to Metric
Reply #1 on:
September 20, 2010, 08:10:26 AM »
is the code calling it back to inches, or don't you get that far.
angel tech
499
Reply #2 on:
September 20, 2010, 08:11:53 AM »
do you need to reboot mach to change to metric
CJCNC
24
Reply #3 on:
September 20, 2010, 08:17:02 AM »
The DRO is going back to inches.. It happens after I jog to the workpiece and zero in.. Also, I try to change the scale to half.
I have not rebooted since, do you think it will make a difference?
angel tech
499
Reply #4 on:
September 20, 2010, 08:20:22 AM »
i think you have to reboot mach to change the units
CJCNC
24
Reply #5 on:
September 20, 2010, 09:07:26 AM »
I rebooted Mach3, but to no avail..
It just keeps reverting back to inches.
angel tech
499
Reply #6 on:
September 20, 2010, 09:12:42 AM »
is there a g20 in your opening lines of code
CJCNC
24
Reply #7 on:
September 20, 2010, 09:27:51 AM »
yes there is, but this happens before I even run the code..
I think I might have the solution.. I found an XML file on the site that makes my CNC machine.. I will try it and let you guys know
CJCNC
24
Reply #8 on:
September 20, 2010, 10:51:15 AM »
Problem Solved.
It turns out that my machine (a Syil X4) requires a different XML file for metric. I loaded it and it worked like a charm.
Thanks for all your input
angel tech
499
Reply #9 on:
September 20, 2010, 12:56:04 PM »
no probs, glad it's sorted.
Print
Pages:
1
Go Up
« previous
next »
