Hello Guest it is June 09, 2026, 12:24:35 PM
Author Topic: adding an optical switch to the spindle  (Read 7905 times)
« on: September 18, 2010, 02:49:43 PM »
Is there a favorite part# that most use for optical switches?  I would like to find one that would
Have electronics onboard to allow me to hook up directly to mach. I don't know enough about them
To make an intelligant decision.
Re: adding an optical switch to the spindle
« Reply #1 on: September 18, 2010, 03:06:36 PM »
Optek OPB917B is what I used, only need to add a resistor on the LED positive wire to limit current. 220 Ohm for the 5v supply is what I use.
« Reply #2 on: September 18, 2010, 11:08:09 PM »
thanks,
  i'm not sure but does it look like it should be able to switch 24v on the output side?
steve
