Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 26, 2012, 09:30:58 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
rounded corners
Pages:
1
Go Down
« previous
next »
Author
Topic: rounded corners (Read 450 times)
lunaj76
Active Member
Offline
rounded corners
on:
September 14, 2010, 08:16:28 PM »
I am having some difficulty with my cv settings. I have cv on and stop cv on 90 angles. I am getting square corners if I cut clockwise but rounded corners cutting counterclockwise. What am I missing?
Justin
Tweakie.CNC
Active Member
Offline
Super Kitty.
Re: rounded corners
Reply #1 on:
September 15, 2010, 01:48:24 AM »
Sounds silly but are you looking at the tool radius as being your rounded corners ?
Success consists of going from failure to failure without loss of enthusiasm. Winston Churchill.
stirling
Global Moderator
Offline
UK
Re: rounded corners
Reply #2 on:
September 15, 2010, 03:44:04 AM »
What version of Mach are you using? - This was a problem I reported back in 2007, but it was then fixed and I havn't seen it again since.
lunaj76
Active Member
Offline
Re: rounded corners
Reply #3 on:
September 15, 2010, 08:55:58 AM »
Tweakie,
The corners look like the machine is trying to skip out on cutting all the way to the end of the line.
Stirling,
It is version R3.042.020
My machine is a gantry type router, I am trying to cut cabinets with a 5 mm bit in .75 material, 3 passes climb cut and 1 pass conventional to realease the part. Corners look great for the 3 clockwise passes but on the final pass counterclockwise the corners get misshaped or rounded.
Thanks for your help
stirling
Global Moderator
Offline
UK
Re: rounded corners
Reply #4 on:
September 15, 2010, 10:18:21 AM »
OK - I just tested R3.042.020 and it appears to be fine - no signs of the "old" CW/CCW CV trouble.
Quote from: lunaj76 on September 14, 2010, 08:16:28 PM
I guess you mean you have it set to "Stop CV on angles > 90" i.e. "greater than" - not "on" so to stop CV (if that's what you want) and you're cutting right angles you'd need to set this value to 89 degrees or so - i.e. NOT 90 degrees.
That however does not explain why CW passes are different to CCW passes - unless of course the feedrates are different.
lunaj76
Active Member
Offline
Re: rounded corners
Reply #5 on:
September 15, 2010, 01:17:30 PM »
I just retested and here are the results.
CV turned on, stop CV on angles >89 on, CV distance tolerance .005 on,
clockwise 3 passes, I get square corners, 1 pass counter clockwise great corners,
Here is the problem,
I cut and oval and a square, the oval cuts really choppy but the square is good.
So I changed the settings to this
CV turned on, stop CV on angles>89 on, CV distance tolerance 5 on.
3 cw passes on the square great corners, oval cuts smooth, 1 pass ccw pass on the square rounded corners.
Strange!
lunaj76
Active Member
Offline
Re: rounded corners
Reply #6 on:
September 15, 2010, 02:19:16 PM »
Upgraded and it works now. Yeah!
stirling
Global Moderator
Offline
UK
Re: rounded corners
Reply #7 on:
September 16, 2010, 04:49:01 AM »
Quote from: lunaj76 on September 15, 2010, 02:19:16 PM
That's good but what's REALLY strange is it all works fine in MY R3.042.020. This is EXACTLY the problem that used to happen a few years back.
Everything in your testing/results makes perfect sense and is what SHOULD happen EXCEPT for the very last bit "1 pass ccw pass on the square rounded corners." which was your original problem. Don't suppose you could post your test gcode (square and oval) just for interest.
Ian
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
