May 27, 2012, 01:52:19 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  New problem with Mach
Pages: 1   Go Down
Print
Author Topic: New problem with Mach  (Read 440 times)
ranchak
Active Member
Offline Offline
View Profile
« on: September 13, 2010, 04:22:59 PM »
I managed to cut a few parts correctly. I am starting a new run of parts that I haven't made before. I noticed that my x coordinates are flipped about the y axis. What I mean is I need the first hole at -1.7250,.5250. I need the second hole at 2.6393,-.6377. Mach will drill the first hole at the second holes location. I've checked my g code and it is correct. I didn't change anything in my settings between yesterday and today, but obviously something has happened. Any ideas??
Active Member
Online Online
Carnoustie, Scotland
View Profile
« Reply #1 on: September 13, 2010, 04:57:31 PM »
Not understanding, you say Mach drills the first hole at the second holes coords and that it seems like the X is flipped about the Y. If that was the case would the hole not be X1.7250 rather than X2.6393
You sure the first hole is being seen by Mach?
Can you attach your code?
« Last Edit: September 13, 2010, 04:59:06 PM by Hood » Logged
ranchak
Active Member
Offline Offline
View Profile
« Reply #2 on: September 13, 2010, 07:52:00 PM »
Hi Hood, sorry I guess I wasn't clear. Let's start over. The first hole is to be drilled at -1.7250, .5250 in Quadrant 2 (upper left), Mach drills it in Quadrant 3 at -1.7250, -.5250. I did go into my motor settings and change Y axis DIR to Active Low. Now everything is running properly, but why didn't this occur when I first set up Mach?
* Anchak and Sons MachXML.exe (123.92 KB - downloaded 18 times.)
Active Member
Online Online
View Profile
« Reply #3 on: September 14, 2010, 01:15:12 AM »
Sounds like somehow your axis has been reversed, maybe someone changed the reverse setting in Homing and Limits?
ranchak
Active Member
Offline Offline
View Profile
« Reply #4 on: September 14, 2010, 01:32:00 AM »
I don't use Homing and Limits. I checked it and nothing is active.
ranchak
Active Member
Offline Offline
View Profile
« Reply #5 on: September 14, 2010, 01:40:35 AM »
Also I am the only one who is here in the shop.
Active Member
Online Online
View Profile
« Reply #6 on: September 14, 2010, 02:04:50 AM »
Strange. Hopefully all will run fine from now.
Pages: 1   Go Up
Print
Jump to:
