Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 01:43:23 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Backlash compensation: config option
Pages:
1
Go Down
« previous
next »
Author
Topic: Backlash compensation: config option (Read 523 times)
leaveme
Active Member
Offline
on:
September 12, 2010, 06:08:50 AM »
Hey guy's:
I have some backlash in my X and Z axis.
For one inch move, dial indicator shows 1.004" in X and 0.997" in Z axis. So the backlash is 0.004" in X and -0.003" in Z.
How do I configure it Mach3? Appreciate if someone can shed some light on this.
regards
My CNC Store:
http://liana-tech.com
_____________________________
Global Moderator
Offline
Re: Backlash compensation: config option
Reply #1 on:
September 12, 2010, 07:06:39 AM »
in Mach:
Config>Backlash... put the backlash values in for the axis, suggest 50% value for speed, click enabled and Ok, and then restart Mach.
Overloaded
Global Moderator
Offline
Reply #2 on:
September 12, 2010, 08:40:39 AM »
Are you sure you are checking for the backlash properly ?
Looks like you may just be verifying the "steps per".
The indicator shouldn't read MORE than the commanded move in either case.
http://www.machsupport.com/forum/index.php/topic,12513.0.html
Russ
"I haven't failed. I've just found 10,000 ways that won't work." Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
Global Moderator
Offline
Reply #3 on:
September 12, 2010, 09:03:28 AM »
Hey Russ, thanks for the clarification.
Had the selective reading glasses on.....
Jeff_Birt
Active Member
Offline
Reply #4 on:
September 12, 2010, 09:12:38 AM »
You cannot check backlash over a distance like 1" or more, if you try you'll start measuring pitch error in the leadscrew which is a whole different animal. To check backlash you run the axis a good distance (say 0.1") one direction to take out any backlash and preload your indicator. Then move in 0.001" steps the opposite direction. As soon as the needle move on the indicator - STOP - . The difference between the number of steps you made, lets say 5 - 0.001" steps, and how far the indicator moved, let's say 0.0005" is the backlash. You should repeat the measurement several times and be able to get the same result. If you can't get a reputable result then you have other mechanical issues that need to be resolved (something loose, flexing, etc.)
Happy machining , Jeff Birt
Check out
www.soigeneris.com
leaveme
Active Member
Offline
Reply #5 on:
September 12, 2010, 11:49:44 PM »
Quote from: Jeff_Birt on September 12, 2010, 09:12:38 AM
You cannot check backlash over a distance like 1" or more...
Thanx Jeff. My understanding was something different
Your information really helps me. I'll try your advised way...
My CNC Store:
Jeff_Birt
Active Member
Offline
Reply #6 on:
September 13, 2010, 07:01:53 AM »
When I first started out I tried a lot of things the wrong/hard way too.
It's all part of the learning process.
Check out
www.soigeneris.com
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
