May 27, 2012, 01:16:28 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  switching
Pages: 1   Go Down
Print
Author Topic: switching  (Read 482 times)
stirling
Global Moderator
Offline Offline
UK
View Profile WWW
« on: September 08, 2010, 05:12:33 AM »
I need to switch 18V 10mA via TTL (turn on/off a plasma torch via the parallel port).
A relay seems a bit overkill for this - doesn't it? and I read somewhere (I think) that such low current is not best switched by a SSR - true? or have I made that up?
Thoughts on cheapest/bestest/nicest/properest way to do this?
Ian
manmeran
Active Member
Offline Offline
View Profile
« Reply #1 on: September 08, 2010, 09:16:41 AM »
18V 10mA
cheapest way is transistor.
on-off
Amir
**Even a clock that does not work is right twice a day**
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #2 on: September 08, 2010, 12:08:59 PM »
Ian,
The common SSR's need to switch a/c loads as they require the zero crossing point for switching off but having said that I switch my cross hair pointer on / off with a mains connected SSR which powers the wall wart to output the 5Vdc for the pointer. The SSR, which has internal opto isolation, is powered directly from the LPT port.
« Last Edit: September 08, 2010, 12:11:50 PM by Tweakie.CNC » Logged
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
stirling
Global Moderator
Offline Offline
UK
View Profile WWW
« Reply #3 on: September 10, 2010, 03:07:15 AM »
OK guys - thanks.
Tweakie - have you looked at logic level mosfets for your cross hair pointer - they sound like the mut's nuts for that.
Ian
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #4 on: September 10, 2010, 03:26:40 AM »
Thanks Ian but I needed -5volts (relative to the frame) because the body of the pointer is connected to + so it was easier, for me at the time, to get the required negative voltage from a wall wart.
Yes I agree that these logic level switching MOSFET's would be brilliant for a lot of applications. (more circuit board routing is on the cards)  Grin
manmeran
Active Member
Offline Offline
View Profile
« Reply #5 on: September 10, 2010, 09:24:12 AM »
logic level mosfets
Using them is not suitable for this issue.
you need only 10ma .you can build a simple circuit by transistor.
Amir
stirling
Global Moderator
Offline Offline
UK
View Profile WWW
« Reply #6 on: September 10, 2010, 11:03:31 AM »
I was suggesting them for Tweakie's laser not my trigger Amir. Keep up  Grin
manmeran
Active Member
Offline Offline
View Profile
« Reply #7 on: September 10, 2010, 11:47:59 AM »
sorry. my mistake
Pages: 1   Go Up
Print
Jump to:
