Hello Guest it is June 11, 2026, 08:53:46 PM
Author Topic: ALL AXIS MOVE WHEN POWER IS APPLIED  (Read 8866 times)
« on: September 07, 2010, 06:27:54 PM »
THE MACHINE WAS WORKING, BUT NOW WHEN I APPLY POWER TO THE DRIVES THEY ALL STARTMOVING.  I CAN CHANGE DIRECTION OF MOVEMENT WITH THE JOG BUTTONS, BUT CAN'T STOP MOVEMENT......USING A 3 AXIS PROBIIX........
« Last Edit: September 07, 2010, 06:37:32 PM by inivator »
Re: ALL AXIS MOVE WHEN POWER IS APPLIED
« Reply #1 on: September 08, 2010, 01:20:29 AM »
Do the DROs in Mach show movement?
« Reply #2 on: September 08, 2010, 08:19:30 AM »
NO...USING STEPPERS, AND WHERE WOULD THE DRO BE SHOWING..
« Reply #3 on: September 08, 2010, 09:13:44 AM »
maybe "GROUND"
check your ground between PC and driver.
Amir
**Even a clock that does not work is right twice a day**
« Reply #4 on: September 08, 2010, 09:28:25 AM »
The readouts in Mach for each axis. Do they show the axis is moving when your motors move and are not meant to be?
