Hello Guest it is June 13, 2026, 05:25:30 AM
Author Topic: Feedrate with SS and MSM problem  (Read 40292 times)
Re: Feedrate with SS and MSM problem
« Reply #10 on: September 06, 2010, 11:25:33 AM »
What version of the SS plugin are you running?
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #11 on: September 06, 2010, 09:05:20 PM »
I will check tonight when I get home.  I am in Mongolia so my days are your nights.
« Reply #12 on: September 07, 2010, 03:11:51 AM »
I too have been running all the BETA releases of the new MSM and have echoed all of the issues experienced which have all been fixed in subsequent fixes with thanks.
The latest BETA 9 release makes all my feed rates go haywire when previous versions where stable, i set it at 2500mm / per minute but it seems to disregard the feed rate and run at whatever it wants to the point i need to downgrade to the previous release.
I am not running any smooth steppers, just a plain vanilla install of the MSM packages.
« Reply #13 on: September 07, 2010, 04:53:06 AM »
I am running Beta2 Ver 0.015.  Thanks
« Reply #14 on: September 07, 2010, 05:22:37 AM »
Hmm... Okay please send me both of your XMLs and we will see what we can do. I need to head out and work on the road today but I will be back at it tomorrow to see if we can get this feedrate problem sorted out.
loderunner, Could you please tell me what frequency you are running at (on the diagnostics page for the 1024.set and on the P Port page of the MSM set) Then I would like to know what you are set for under config ports and pins
THanks
Brian
www.machsupport.com
« Reply #15 on: September 07, 2010, 06:13:11 AM »
Brian,
Running 35251 Frequency on both the MSM and 1024.set as well as the config screen. (I sent you my XML along with the screen dumps of the info you requested)
« Reply #16 on: September 08, 2010, 09:39:57 PM »
I am attaching the MachStdMill xml file I am using.
« Reply #17 on: September 10, 2010, 08:14:05 PM »
I am told that the feed rate issues are repaired in mach 3.43.22
see http://www.machsupport.com/forum/index.php/topic,15471.msg107016.html#msg107016
www.CalypsoVentures.com
« Reply #18 on: September 11, 2010, 04:41:16 AM »
It works !!!
Thanks for the fast fix on this bug Brian.
« Reply #19 on: September 11, 2010, 06:26:46 AM »
Fixed my problem as well.   Thanks
