Hello Guest it is June 09, 2026, 07:30:19 AM
Author Topic: screen4 can´t load screenset )-:  (Read 39996 times)
« on: September 01, 2010, 03:26:16 AM »
need help....- after installing a new motherboard,
I can´t install or use screen4 any more...
Can open the screen4 program and locate the screen....set file,
but the functional screen.set does not open in screen4 - instead
I see one small message window with yellow exclamation mark  sign...
than the screen4 surface stalls - i have to kill it in the windows xp system...
any hints?
would be glad to get it working again ((-:
thanks
timmi ???
Re: screen4 can´t load screenset )-:
« Reply #1 on: September 01, 2010, 06:08:42 AM »
Go to Defaults menu and point to the Mach3 folder.
Re: screen4 can load screenset (-:
« Reply #2 on: September 01, 2010, 07:19:47 AM »
thank you!!!    easy, fast & great solution!!!!!    :D :D
« Reply #3 on: October 19, 2011, 12:17:15 PM »
Gerry, what does Screen4 need from the Mach3 folder?  I'd like to install Screen4 on my thumbdrive so I can work on screensets during my lunch hour, on a PC without Mach installed.  Copying over my *set and birmaps folder doesn't work so I figure something else is missing.  I haven't been able to find the answer here in the forums, maybe I'm searching wrong...
Randy
« Reply #4 on: October 19, 2011, 12:40:00 PM »
Randy,
I "think" it needs the screen 4 xml file as well.
« Reply #5 on: October 19, 2011, 12:44:24 PM »
Yes, just loaded the Screen4 xml, the screen 4 program and the bitmaps folder and it loaded right up.
« Reply #6 on: October 19, 2011, 01:04:17 PM »
Ah, great, thank you very much for the quick reply, Dave.  I will give that a try tonight.
Randy
« Last Edit: October 19, 2011, 01:07:47 PM by zephyr9900 »
« Reply #7 on: October 19, 2011, 01:56:55 PM »
I'll check when I get home.
« Reply #8 on: October 19, 2011, 04:14:17 PM »
Thank you, Gerry.
Randy
« Reply #9 on: October 19, 2011, 05:49:55 PM »
I think you'll also want:
buttons.txt
DROs.txt
and
Leds.txt
It would appear that these are lists for predefined objects.
I would think that the .xml would create itself when running Screen4, since it doesn't come with the download, and there's no installer.
