May 27, 2012, 12:14:12 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Newfangled Solutions Wizards (Moderator: Ron Ginger)
| | |-+  Write Wizard
Pages: 1   Go Down
Print
Author Topic: Write Wizard  (Read 731 times)
sandcrab
Active Member
Offline Offline
View Profile
« on: August 30, 2010, 09:13:58 AM »
I have tried to to get "Write" in the wizards to load a G code for simple engraving, but it will not post. Last week while working with the wizards and Lazy Cam I received a message that an axis was disabled, but that hasn't repeated. The Lazy Cam G code loads, but all fonts cut double line.
If you think you can't do it, you're right.
Global Moderator
Offline Offline
View Profile
« Reply #1 on: August 30, 2010, 04:44:06 PM »
Did you fill in all the inputs, select a single line type of font, but........when all done you need to click the "WRITE" key on the wizard keyboard.
Otherwise it's won't post the gcode.  Wink
sandcrab
Active Member
Offline Offline
View Profile
« Reply #2 on: August 30, 2010, 08:18:50 PM »
That did it Rich, Thanks. I'm not sure if I changed any inputs that mattered, but when I touched the write key, it stayed depressed until the G code had loaded and then reverted to the Mach3 screen and cut single line.
Pages: 1   Go Up
Print
Jump to:
