Hello Guest it is June 10, 2026, 01:11:18 PM
Author Topic: Soft Limits  (Read 16416 times)
Re: Soft Limits
« Reply #10 on: August 28, 2010, 06:05:44 PM »
Can you attach your xml and I will check your config. Also  a pic of your machine may help.
Soft Limits Again
« Reply #11 on: August 29, 2010, 10:46:55 AM »
I think I found why I couldn't set soft limit to green!  There is a dotted rectangular box on my table!  If I'm within that area my
soft limit light will stay on!  I can't figure out how to change that dotted line to reflect the actual size of my table
X = 48  Y = 24   Appreciate any help!  SPANKY
Re: Soft Limits
« Reply #12 on: August 29, 2010, 12:29:06 PM »
 You either have something not configured right or you are not doing the homing sequence correctly. Please attach your xml and I will have a look at your config, also a pic of your machine may help.
