May 26, 2012, 09:19:03 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  max lines of code
Pages: « 1 2   Go Down
Print
Author Topic: max lines of code  (Read 1146 times)
Picengraver
Active Member
Offline Offline
View Profile
« Reply #10 on: August 28, 2010, 05:59:59 PM »
I typically cut 600,000 lines (+ - a few) engraving lithophanes.  Never a problem with Mach3 burping.
John Champlain
moorea21
Active Member
Offline Offline
View Profile
« Reply #11 on: August 28, 2010, 06:02:59 PM »
Lithophane... learn something new every day. Do you have pictures, or links to pictures? I'm curious to see what you do...
Rich B
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #12 on: August 28, 2010, 06:08:43 PM »
If it comes out OK, I'll post a picture in an hour or so.
Picengraver
Active Member
Offline Offline
View Profile
« Reply #13 on: August 28, 2010, 06:27:41 PM »
OK, trying to post a picture again - don't know what happened other two tries.
This is a smaller litho I did recently.
John Champlain
[attachment deleted by admin]
Picengraver
Active Member
Offline Offline
View Profile
« Reply #14 on: August 28, 2010, 07:12:09 PM »
Hope I haven't messed up this thread.  I can not see anything but a solid blank screen on page 2 for some reason. Strange ?
John Champlain
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #15 on: August 28, 2010, 07:52:23 PM »
First Litho I ever tried.
derek
Active Member
Online Online
View Profile
« Reply #16 on: August 29, 2010, 01:38:17 PM »
I've run over a million lines before on some large patterns. 30 - 40 hour continuous cut times with no problems. Unless of course you forget to turn off the tool path display before you load!
Derek
Pages: « 1 2   Go Up
Print
Jump to:
