Hello Guest it is June 10, 2026, 02:10:02 AM
Author Topic: max lines of code  (Read 21753 times)
Re: max lines of code
« Reply #10 on: August 28, 2010, 05:59:59 PM »
I typically cut 600,000 lines (+ - a few) engraving lithophanes.  Never a problem with Mach3 burping.
John Champlain
« Reply #11 on: August 28, 2010, 06:02:59 PM »
Lithophane... learn something new every day. Do you have pictures, or links to pictures? I'm curious to see what you do...
Rich B
« Reply #12 on: August 28, 2010, 06:08:43 PM »
If it comes out OK, I'll post a picture in an hour or so.
« Reply #13 on: August 28, 2010, 06:27:41 PM »
OK, trying to post a picture again - don't know what happened other two tries.
This is a smaller litho I did recently.
John Champlain
[attachment deleted by admin]
« Reply #14 on: August 28, 2010, 07:12:09 PM »
Hope I haven't messed up this thread.  I can not see anything but a solid blank screen on page 2 for some reason. Strange ?
John Champlain
« Reply #15 on: August 28, 2010, 07:52:23 PM »
First Litho I ever tried.
Offline derek
  •  200 200
« Reply #16 on: August 29, 2010, 01:38:17 PM »
I've run over a million lines before on some large patterns. 30 - 40 hour continuous cut times with no problems. Unless of course you forget to turn off the tool path display before you load!
Derek
